Mk1 Perspex Windows
  • knightenvironmental
    • Jun 2010
    • 34
    Mk1 Perspex Windows
    Hi, I'm thinking of fitting Perspex door glass to my 2 door mk1 with sliders. I'm going no to use single piece without the quarter window. Does anyone know if I have to gut through the 2 welded joint that join the outside and inside sections of the door at the quarter light end? Thanks
    Re: Mk1 Perspex Windows
    I presume that you're talking about the strip where the 1/4 light sits? You should only need to cut that if the Perspex window is too deep to fit with it there.
      • Jun 2010
      • 34
      Yes it's the two strips where the quarter fits. There is no Wayne can get the Perspex in with them there And wondered what others have done.
        They have been cut out of the doors on my race car which uses 1 piece Perspex windows.
          • Jun 2010
          • 34
          Great thanks. Does it effect the stability of the doors or are they still solid?
          • James Jordan
            • 284
            Im looking at the same think. Any recommendations on which window kit to use?
            James
            • AlexA
              • Aug 2009
              • 218
              Same with mine.
              what window rubbers or fittings is everyone using with the one piece Perspex window ?
                Mine are held in with stuff from my local windscreen fitters, it's what they use on rear glasses in Volvos etc and comes on a roll.
                • AlexA
                  • Aug 2009
                  • 218
                  Any pics or links please ? is it just typical rubber stripping or does it have any aluminium strip ?
                  • rallyrob
                    • Apr 2010
                    • 2739
                    You shouldn't have to cut the front quarter light channel out of the door anyway.
                    There's a bolt/screw in the bottom of it and 1 or 2 pop rivets that hold it to the main top frame of the door.
                      http://www.kenteurope.com/en/product...indscreen-tape. Same as this.
                      • AlexA
                        • Aug 2009
                        • 218
                        cheers PK
                        feel free to post up some pics of your Mk1.
                          cheers PK
                          There are plenty on here already
