Historic Touring Racing Mk2 Escort
  • wxneypar
    • Mar 2011
    • 110
    #16
    Re: Historic Touring Racing Mk2 Escort
    Good afternoon everyone!
    Yesterday I won a race for the first time ever! So I'm super excited to continue improving the car.
    I think now is the time for a rear suspension upgrade.
    My current setup is original 1600 Sport export setup (Anti Rollbar and multi leaf springs on uprated shocks and that's it)
    I cannot use anyting that has not been fitted to the same model so I was thinking to go to:
    - Remove ARB
    - Add original Anti Tramp bars (like this kit https://www.motorsport-tools.com/esc...d-rs-type.html )
    - Improve shocks (Don't know which)
    - Add one more leaf to stiffen it to counteract the lack of ARB
    BTW I am not allowed to use any kind of LSD
    So my concern is: Will I miss the ARB on high speed corners? Will this improve grip when accelerating out of the corners?
    Maybe I am completely wrong and this doesn't help at all with corner speeds, so I'd like to hear you thoughts on a full tarmac-circuit race car.
    Thanks in advance,
    Peter
    • turbospud
      • Jan 2005
      • 670
      #17
      well done on the first win,
      i would keep the roll bar in preferance to tramp bars,can you fit a panard rod or axle location kit under the rules
      leaf springs i would go single spring and set them[decamber] for the ride height you want,dont use blocks
      gaz adjustables are a cheap option for experimenting with
      • wxneypar
        • Mar 2011
        • 110
        #18
        Thank you!
        Sadly I cannot fit/add any kind of bars or axle location kit that was not an original or optional equipment, and I think there was no escort mk2 with panhard or watts linkage.
        Using original anchor points I can modify or make adjustable any kind of bar. For example, fitting an uprated ARB can be done, but I'm worried it would lift the inside wheel on hard cornering and make me lose traction (no LSD allowed)
        Also I can use any shock that is NOT adjustable and fits in the original location.
        I have heard a lot of S### about both ARB's and tramp bars, but it seems to be a lot of info on rally suspension setups but not for circuit racing on mk2's.
        Yeah, I know this rules are really difficult to deal with, but there should be something I can do to make it better I guess.
        Thanks in advance,
        Peter
        • turbospud
          • Jan 2005
          • 670
          #19
          that makes it harder when your not allowed additions.
          as graham says above stiffer springs/roll bars will stop it lifting wheels or lighter springs/stiffer roll bars
          locate the rear axle as best you can ie weld spring plates to axle,throw the rubber away etc
          bilstein gp1 type shocks used to be the thing for the road car classes over here
          • wxneypar
            • Mar 2011
            • 110
            #20
            So the general idea would be NOT to put the tramp bars instead of the rollbar?
            Like this for example? It says rally there
            Not to be confused with the Bilstein B6 and B8 sport damper ranges these shock absorbers are designed specifically with Motorsport in mind.Bilstein Motorsport dampers have been used by Motorsport professionals and clubman racers alike in all forms of motor racing and have been the choice of winning teams for many years. The name 'Bilstein' is synonymous with Motorsport and that is because of their constant research and testing to produce the very best dampers for competition use.Developed using Bilsteins 'Upside down' monotube technology to produce a damper which is able to withstand the harsh environments in racing or rallying. This technology allows for a larger surface area on the piston which gives increased damping for better spring control and ultimately better handling. Heat dissipation is also improved so the dampers give predictable performance even when worked hard.This damper range are non adjustable and fixed height (unless otherwise stated) and most applications are specific to Motorsport disciplines i.e. Race, rally or group N.
            Are they good for chasing seconds around the lap on a tarmac circuit?
            • wxneypar
              • Mar 2011
              • 110
              #21
              Some photos of the last race for references on body roll and to make the thread more interesting
              • Miniliteman
                • Feb 2004
                • 5051
                #22
                Hello,
                with a car like yours, unarched, road tyres, limited bhp, no LSD, you will need a relatively soft sprung rear end.
                To try a different setup change one item and one item only and see how it feels and how the lap times are (practice).
                Maybe loosen the rear ARB on one end so it isn't working anymore.
                And/or try a fast road type of rear damper, so not a stiff Bilstein; changing the dampers is a quick job so it can be undone in the same time.
                • turbospud
                  • Jan 2005
                  • 670
                  #23
                  yes,a well mounted roll bar will give you a level of anti tramp,tramp bars wont give you roll control
                  yes those ones gp1 type, but back in the day you got 2 different setting types,race or rally
                  from where you are now,i dont think dampers will give seconds its going to be a combination of lots of things
                  • wxneypar
                    • Mar 2011
                    • 110
                    #24
                    Yeah! Im not even one second behind at qualy's, I should have said tenth's!
                    So it looks like my original idea of going stiffer on the rear is going to the trash now, is going softer the general opinion?
                    Regarding shocks, I couldn't find any uprated one that doesn't say Rally on it, what kind of rates am I looking for?
                    • turbospud
                      • Jan 2005
                      • 670
                      #25
                      [ATTACH=CONFIG]84156[/ATTACH]
                      [ATTACH=CONFIG]84157[/ATTACH]
                      [ATTACH=CONFIG]84158[/ATTACH]
                      [ATTACH=CONFIG]84159[/ATTACH]
                      [ATTACH=CONFIG]84160[/ATTACH]
                      its looks pretty good i would have said,maybe drop the front ride height a bit,
                      it looks as if your on around 3deg camber,5deg castor,i found less of both worked better with softer springs.
                      as minilight says change one thing at a time and see how it feels
                      • Miniliteman
                        • Feb 2004
                        • 5051
                        #26
                        As turbospud said on the photos the car looks to be "sitting" ok.
                        Do you have a movie (youtube ?) of your car in action?
                        For rear dampers look for yellow Koni's; these are adjustable for rebound but only when removed from the car. There is no button like the Gaz dampers have.
                        • wxneypar
                          • Mar 2011
                          • 110
                          #27
                          I do! Let me upload it to youtube so I can share here!
                          Just promise you'll look at the car and not my (poor) handling of it :P
                          • wxneypar
                            • Mar 2011
                            • 110
                            #28
                            As requested Personal best lap this weekend:
                            Any kind of feedback is well received
                            • Miniliteman
                              • Feb 2004
                              • 5051
                              #29
                              Nice.
                              Think the limiting factor are the tyres (and bhp).
                              Spending lots of money and time on the car will give a few tenths maybe.
                              Get some advice from more experienced drivers on what lines to drive on the track and left-foot braking etc.
                              • Arieke
                                • 442
                                #30
                                Car looks good. 160km/u straight line. Nice for a engine with 134hp. what axle ratio do you use?
