    hope you've knee pads mate , they're a lifesaver..
      There's some kneelers in the back of the shed, so I'll get the torch out tonight, and brave the cobwebs. I've been kneeling on an old bath towel, folded up, but its not got much give in it. My ankles were hurting too. Working outside certainly takes its toll.
        Almost finished the dash. 8-)
          Tacho turned up this morning, so I'll fit that tonight.
          The small toggle switches I've used (for reference) on the front panel are from rswww.com
          And the push button with the rubber cover (same type as used by Stack on their rev counter tell tale switch) is
          and the rubber switch cover, sold seperately is
          The LED indicators are 265-6829, 265-6807 and 265-6835 (all now discontinued)
          Vehicle wiring products sells the same switch and cover, for about 3 times the price of RS ! I know, I bought one from VWP and it came in an RS bag with the part number on the outside. Doh!
          Loads more crimping last night, almost ready to insert all the wires in to the control box connector housing, and start testing the power circuits/lights etc.
            Fitted the stack tacho and switch, and moved the Ford emblem down.
            Tonights project is to wire it all up.
            Finished the control box connector last night. Now its the two ECU connectors to complete, and she's good to go!
              The dash looks great, top work
              Must be nearly time for the big start-up now
                Just need to finish the ECU connectors, test the ignition and injectors, plumb the radiator in, plumb the fuel lines for the throttle bodies in, connect a throttle cable, and it will run. 3-4 weeks top.
                  looks excellent, don't think I am going to be able to measure up to that standard, not even close
                    Praise indeed!
                    Lots of lovely dashboard spaghetti. Will finish it tonight (tues), and power it all up to test the instruments and LED's
                    The amber alternator warning LED takes it power from the supply for the ignition coil, so the LED only comes on when the ignition switch is in the On position. The oil pressure and gear shift LEDs take their power from the main +12V feed for the dash, so these are always 'live'.
                      Stack heaven... Couldn't resist sticking it on the battery.
                        Ran out of crimps so I couldn't finish the wiring on Friday evening. So I've set about mounting the carbon dash in the car, and made one support strut last night out of steel tubing, which supports the front of the dashboard (which is now pretty heavy with all the instruments inside). Slow progress, but progress all the same. Got a bollocking for going outside on Valentines day, but I'm sure the Fiesta didn't mind the attention. 8-)
                        The www.zetecinside.com website has had a makeover during the weekend. It now uses CSS for positioning, which makes it far easier to modify in the future, as one style sheet controls the layout. Just over half of the archive news pages are converted, with another 70 or so pages left to convert. I've removed the google ads, as they slowed everything down. So if anyone wants to place an advert on the site, get in touch....
                        If the website looks a bit doolally, press ctrl-F5 to force your web browser to reload all the styles etc.
                          Here's the dash mounted in the car
                            Just a shame it's not called duratecinside...
                              I know. Tough call. Everyone knows the car as "Graham's zetecinside Fiesta", so I think I'll stick with the name.
                              I do also own the www.duratecinside.com domain name though, so maybe one day.....
                                • 25229
                                seeing as ford put duratec badges on a zetec your just have to put zetec badges on a duratec !!!!!!!!!!!!!!!!
