    • 976989
    In your trace above are the pink lines meant to be cam ?
      Yes, but thats when cranking
      I took an oscilloscope picture when the engine was running on Sunday, and all the vertical yellow lines were all the exact same amplitude. But that was with sequential switched off, so i reckon the software capturing the data from the crank and cam was ignoring the cam signal.
      Maybe I'll bring the laptop along on Sunday at the CF show and we can have a go at getting it running then 8-) The backfires should clear the field!
        I have created a new map with 90deg as the reference angle and batch mode and it runs beautifully.
        Washed the car and its ready for the trip to classic Ford in the morning.
          Nice one Graham!! No video?
            Brilliant, glad it all running OK, funny how it is so often just one simple setting, simple after you have found it, that is
            • 4drmatt
              • 2079
              good stuff... look forward to seeing it at pod later
                Had a great time at the show yesterday, but goddamit, that Jet Car is fecking loud. I almost dropped my camera.
                The car is extremly dirty now, but thats they joys of towing it on muddy roads, and thats just inside the Santa Pod venue.
                The queues to get out were pretty bad, everyone remained patient, and we were soon on our way.
                I ran the engine with the new map, for the Fiesta boys on the Sh*tbox Racing stand, and she's running a lot better now.
                I tested the intermittent wiper, sitting in the car, when the torrential rain came down. Worked a treat 8-)
                  But still no video of it running nice?!
                  • 4parajon
                    Tyre Wall Terry
                    • Jun 2006
                    • 3670
                    Can't believe Ive just wasted 20secs of my life watching someone's windscreen wiper working
                    Glad its running well for you mate
                      There was feck all else to do whilst waiting for the rain and the traffic to clear 8-)
                      Just need to let her run long enough to get up to temperature, and make sure none of the hoses blow off under pressure. Wasn't prepared to do that with onlookers.
                      I'll take a video next time she's running. Busy week this week, and wifey seems to have gotten the hump with all the hours I've spent outside, so I've some rebuilding to do by the sound of things. x-)
                        Now, what to do with the removable ally slam panel above the radiator? Polish it, or paint it, red or black, what do you reckon?
                        • turbo m
                          • 1057
                          polish it painting will only add weight.
                            I'll probably get it anodised instead. 8-)
                            Ordering the clutch hose today, stainless overbraided, with dash 4 fitting for the gearbox, and dash 3 banjo for the master cylinder.
                            Spending a lot of time away from home for the next couple of months, so the only time I'll get to work on the car will be a few hours at the weekend, unless I take the car/trailer down to my B&B of course. I dont think they'd mind 8-)
                              Car has AFWO at the moment, and the underside has a much flatter profile than before. Partly due to the lack of engine cradle on the Duratec install, and the Tony Law system. http://twitpic.com/1yji3j
                              I've removed all the wheels so I can bleed the brakes. I may need to order new hoses for the rears, as the position of the HiSpec calipers is different now, and the hoses feel a little too tight for my liking.
                              Expecting the clutch hose today. Will connect that up when it arrives.
                              Snag list comprises of:
                              Bleed brakes
                              Make gearbox steady bar
                              Load new ECU Map v1.1
                              Fit clutch hose
                              Fit rear brake pads
                              Fill gearbox with oil
                              Plumb in extinguisher
                              Refill extinguisher (Expired Mar 2010)
                              Fit brake balance adjuster
                              Fit IB5 output cup on passenger side (replace BC cup as the BC cup doesn't actually fit properly in the oil seal) and purchase 2nd axle-bar from CPS.
                              So plenty of things left to do.
                                But still no video of it running properly!!
