My mk2 Rally car - Duratec power
  • JonSegger
    • 520
    Originally posted by rallyrob
    Okay, thanks. What does it rev to about 7500-8000rpm?
    Yep. I think rev limiter is 8000 rpm. (I did notice last time out that the shift light wasn't working, but that it set at 7200, I believe).
    • rallyrob
      • Apr 2010
      • 2738
      Cheers.
      It's a 4.6 now. (It was originally a 5.1, but that was too low geared.) It's on 15" wheels at the moment too, which gears it up a little for the long Snetterton straights.
      Okay. Even with it revving to 8000, the 15" wheels must definitely help it on the straights too.
      • JonSegger
        • 520
        Yes, for sure, definitely helps. Worth mentioning that it has a Quaife 60G too, which did have a tall 1st gear when I originally bought the gearbox (2.057). I subsequently swapped the diff from a 5.1 to a 4.6 diff and, combined with 15" wheels, it was a struggle to pull away in 1st and putting a lot of strain on the clutch. I had the gearbox serviced recently and changed 1st gear to a 2.4 ratio instead. It is much better now.
        • Forest_rallying
          • Feb 2013
          • 2498
          I have an Escort with a little 2.0 Pinto fitted and I have the same diff ratio and 15 inch like yours Jon. It’s fitted with a Quaife type 9 gearbox fitted with a 2.01 first and Race ratios and despite me making the engine more tractable I feel first gear’s just about acceptable on the flat but too tall to set off on a hill. The engines fitted with a sintred clutch plate which also doesn’t help things either on take off. I had a spare std type 9 so I have decided to fit that with a Tracsport kit with a 2.48 first gear and give that a try.
          • JonSegger
            • 520
            Yes, I checked the clutch when I took the gearbox out to get it serviced and the 1st gear ratio changed. There were cracks in both plates and the cover had broken - so I had to replace the clutch too. I assume that 1st gear being too tall was putting extra strain on the clutch. It was the same as you described - just about able to pull away on flat ground, but any sort of a hill start just didn't feel good. Much better now with the higher ratio/lower gear.
            • rallyrob
              • Apr 2010
              • 2738
              Blimey, yea that clutch was bad, wasn't it!
              • JonSegger
                • 520
                Yep. A good job I got to it when I did I think. That cover would have done a lot of damage if it had properly let go.
                • Miniliteman
                  • Feb 2004
                  • 5068
                  If it's a rally car why not fit a cerametallic clutch?
                  • JonSegger
                    • 520
                    That's what it is - twin plate cerametallic. I went for this one (and the associated cover): https://cbradleymotorsport.co.uk/pro...-1x23t-x-5-6mm
                    • rallyrob
                      • Apr 2010
                      • 2738
                      I know there's probably no warranty as such but I might inclined in send photos of that directly to ttv. I suppose it's been in the car a fair while though hasn't it.
                      • JonSegger
                        • 520
                        That's the new one. The old one was AP plates and a Helix cover.
                        • Miniliteman
                          • Feb 2004
                          • 5068
                          New one is a cerametallic clutch from TTV; old one is a sintered race clutch from AP.
                          • rallyrob
                            • Apr 2010
                            • 2738
                            My apologies, yes I should have looked at the photos better. I realise now it was the old one and the TTV is the new one.
                            • JonSegger
                              • 520
                              no worries. My fault, I didn’t actually explain it very well.
