This is my Cossy lightning rod built on a budget of 500 pounds
its not pretty but it works
it was once a proud cossy before an argument with a brick wall,: rescued from the scrap mans crusher and lives again.
The engine 205 block
2 ltre bored +1mm
Lightened and balanced
Lightened 1600 flywheel and cluch
injection head skimmed for11.1 compresion
stnd valves with 3 angle seats
oil cooler
alloy breather catch tank
baffled sump
high pressure oil pump
Thats how it started
Decided to improve the exhauste system try to get some more power...
Car up on ramps ..
Old system out new power tuned system fitting
Silencer box needs to go in the footwell behind driver so remove floor and new tunnel welded in
Top hat to keep everything square and provide extra heat protection..
New seat mounts /cross brace fitted
Re-locate batterys (everything is fitted on the drivers side to keep the weight on that side because i only turn right being an oval racer)
24 volt starting with 2 seperate 12volt feeds from each battery 1 feed for ignition and the other for every thingelse(electric power steering brake lights ect)
Old seat gone (they burn realy well)(top tip dont weld brackets on seats bolt them on)
New seat with arse protector fitted on base (i think black seats go faster than old blue ones ...? could be wrong)
New seat fitted(new to car) batterys insulated and covered ready to go
all it needs is a coat of paint (not good at pretty ill do it later)
2 ltre bored +1mm
oil cooler
baffled sump
Car up on ramps ..
