mk1 escort st170 (well163 acyually lol)
  • dyn-car-gwyn
    • Mar 2008
    • 724
    #76
    Re: mk1 escort st170 (well163 acyually lol)
    Originally posted by Pedro Motorsport
    The infamous 2 wheel "trons brown" moment!
    yes indeed, a very brown moment! lol
    • dyn-car-gwyn
      • Mar 2008
      • 724
      #77
      right, just a quick update on the car. due to the fact that good st engines are getting thin on the ground, i decided to shell out and buy some shiny bits for the inside of the engine, raise the compression etc. only having done one event with it since the install, i can report that the car is doing well, much much stronger at the top end, and much livlier to drive! i have much to learn with it, but hoping to have a few events under her belt soon. only marginal gains figure wise, but feels much more! dynoman has been kind to start a thread under zetec instalation, 'ST170'
      • Liam_LET
        • Jul 2013
        • 10
        #78
        great to see a st170 engine being 'used'
        • Smithaam
          • Sep 2016
          • 43
          #79
          Very impressive! i'm going to be attempting the same with my ST engine and fitting into a Mk3 Cortina. I want to move the engine as far back as possible but that air box is just in the way and was thinking of changing inlets but after reading your thread i can see it is possible to move it
          • dyn-car-gwyn
            • Mar 2008
            • 724
            #80
            the fitting of the engine is no different to a zetec. the airbox will fit, its essentially "upside down". not sure how youre fixed for space on the Cortina, but it is a squeeze on the mk1. still, its there, and works, very well!! :-)
            • Smithaam
              • Sep 2016
              • 43
              #81
              i have got more room in the Cortina but i want to keep the engine as far back as possible and if i left it as normal in hits the brake master cylinder.
              If i turn the airbox upside down i gives that bit of extra space and should sit in nicely
              Its nice to see someone has done it and been successful lol Thanks
              • dyn-car-gwyn
                • Mar 2008
                • 724
                #82
                Not many had done this conversion when I was doing it.....so it's been a bumpy ride......but more than happy to share my.experience......If u need any pics etc.....just holler
                • Smithaam
                  • Sep 2016
                  • 43
                  #83
                  What alternator are you using and where is it mounted? I have mine fitted with the retro-ford kit and its to high and I cant fit the air box low enough I have looked at changing the inlet but I cant seem to find anything that would work with the original throttle body
                  • katana
                    • May 2012
                    • 3278
                    #84
                    The alternators can be mounted low left or where the PS pump used to reside - you'll have to fab the brackets but its do-able and below the ex. manifold.
                    • Smithaam
                      • Sep 2016
                      • 43
                      #85
                      thanks, looking like putting it lover right under exhaust manifold, that's where it sits now on the Xflow.
                      • katana
                        • May 2012
                        • 3278
                        #86
                        Some piccies added - I know the first two are silvertops but gives an idea!
ID:	2019104Click image for larger version
ID:	2019105Click image for larger version
ID:	2019106Click image for larger version
                        • Smithaam
                          • Sep 2016
                          • 43
                          #87
                          thanks very much for the images, they will help a lot in the fabrication
