Escort Mk 2 1300 Slalom
  • boXXer
    #16
    Re: Escort Mk 2 1300 Slalom
    nice one. beige 4 doors are the fastest
    • max0815
      • Aug 2011
      • 676
      #17
      today we started working.
      First thing is: in some Corners we got slipping Tyres but the LSD work very well. So we found out that we got 1 Tyre up in the air in tight corners.
      We found out that we need more damping way because the shock absorber was complet on block. On Saturday we go to a fella who stopped racing his Escort and we buy his parts he´s got different shock absorber so maybe the problem could be solved by Saturday.
      • robrs2
        • 2406
        #18
        I you dont want to go with tarmac or forest arches there are these types also http://retrorides.proboards.com/inde...t&thread=66146
        • max0815
          • Aug 2011
          • 676
          #19
          Suspension probem is solved we mounted modified bilsteins. They are shorter than the original. So maybe on the weekend the engine gets out. And i got a set of arches on the weekend I make some pictures they are real wide
          • max0815
            • Aug 2011
            • 676
            #20
            Today i fixed the arches with tape. They are too wide.
            Could anybody say me from the picture what kind they are Tarmac, Forest etc?????
            • max0815
              • Aug 2011
              • 676
              #21
              Anybody got an idea which arches those are???
              • rwd2ltrfiesta
                • Jan 2011
                • 1731
                #22
                tarmac 1s i rkn boss
                • Bigfish
                  • 891
                  #23
                  what car is this, im thinking TR7 but im also thinking im wrong?
                  1974 MK1 Escort - Work in Progress
                    • 25243
                    #24
                    Originally posted by Bigfish
                    [ATTACH=CONFIG]48158[/ATTACH]
                    its a Fiat X19
                    • max0815
                      • Aug 2011
                      • 676
                      #25
                      Yes it´s an X19 on of the fastest Fiats in our class. He also have an Fiat 128 in our class
                      • max0815
                        • Aug 2011
                        • 676
                        #26
                        Today was the first real working day on the winter works
                        -Moved the Engine out
                        -Oil and Water Radiators out
                        -started to work on the wiring
                        -started to build a new sheet metal on the tunnel to hold the switches etc
                        -and I cut out pieces of the inner front shet to make more space for the radiators and a air intake
                        -started with grinding the engine bay for a respray
                        more stuff tomorrow
                        • max0815
                          • Aug 2011
                          • 676
                          #27
                          Not many done in the past time still collecting and ordering parts.
                          And started a fxxking job: get rid of the under car sealing
                          warmed everything up with a blow dryer and then with a big screw driver, but I have to try a other way
                          and thinking about more air inlet in the front panel
                          • rwd2ltrfiesta
                            • Jan 2011
                            • 1731
                            #28
                            • max0815
                              • Aug 2011
                              • 676
                              #29
                              Yes sh**t job. Thinking about getting parts of the inner arches dry ice blasted.
                              Finished a new switch panel and fuse panel.
                              The perfect bias pedal box from oldskoolrools arrived today.
                              Wanted to start some welding today but gas of the welder was empty
                              • max0815
                                • Aug 2011
                                • 676
                                #30
                                Pedalbox fit perfect
