Escort Mk 2 1300 Slalom
  • max0815
    • Aug 2011
    • 676
    #31
    Re: Escort Mk 2 1300 Slalom
    Reworked the complete wiring these days and cut out all cables switches and relais i don´t need
    • oldskoolrools
      • 2162
      #32
      wiring weighs a lot! i stripped a complete loom out of a sierra once, very surprised how heavy it was.
      cars coming on a treat, monster arches!
      • max0815
        • Aug 2011
        • 676
        #33
        A little update:
        Wiring done
        exhaust done
        exhaust tunnel done
        waiting for my paket from evodave (classic and rally spares)
        putted a standart engine in today to testdrive the new suspension and the new brake system
        put the fuel regulator in the back
        still so much to do don´t really know if I get all done
        • Miniliteman
          • Feb 2004
          • 5032
          #34
          Hi, these wires connected to the fuseholders will come loose due to vibrations ...
          And if you connect the common +12V like that the first wire has to take all the current of the subsequent fuses so it will get hot.
          • max0815
            • Aug 2011
            • 676
            #35
            I drive this fuse system the 3 season this year without any problems
            • northeee
              i used a wall paper scraper to get rid of the underseal then wiped it over with turps.
              takes forever.
              keep at it.
              • max0815
                • Aug 2011
                • 676
                #37
                i think the underseal will stay because we had only 8 weeks to the first race. Yesterday the new TCA´s got mounted and I try to mount a panhard rod here´s the result:
                We put a standart engine in to drive the pedalbox adjustment and to get the suspension adjusted.
                • max0815
                  • Aug 2011
                  • 676
                  #38
                  We bought a new/ old shell
                  nearly a complet car. it´s a 75 1.3.
                  • robrs2
                    • 2406
                    #39
                    That looks to be in good condition
                    • M11rf
                      • Apr 2004
                      • 4346
                      #40
                      What is the plan for it? Use all the 4 door bits on it? Or use the bits off this one for the 4 door?
                      • max0815
                        • Aug 2011
                        • 676
                        #41
                        the body is pretty solid. we have all the rusty parts as new panels.
                        The plan is building the 2 door shell as new racecar. Building the shell up over the year and put all the spares from the 4 door in it at the season end.
                        Today we got the engine back from the builder he reworked it and put another camshaft in. maybe we wen´t to a wheel and tyre store over the weekend and get the suspension adjusted.
                        • max0815
                          • Aug 2011
                          • 676
                          #42
                          Another month has gone and the car still doesn´t run. We have many smaller problems but the biggest problem we have is that the crank sensor doesn´t work anymore. It wasn´t easy to get a new one because nobody really know´s from which car it is so we finally bought one straight from Van kronenbourg. It should be here at Wednesday last week but nothing happend yet.
                          So the car doesn´t run we can´t go to the dyno and adjust the rebuild engine and we can´t test drive the suspension set up and the new brakes.
                          Don´t look like a good season this year
                          • max0815
                            • Aug 2011
                            • 676
                            #43
                            Today we had everything we need and all the stuff done. So we started the engine. Nothing happend fuel was there, had a spark etc. So we checked a few things on the engine. So we liftet the engine cover checked the timing and the valve adjustment. And look what I saw:
                            the pushrods hit the hole
                            I think we need another engine builder
                            • Hoogi
                              • Jul 2008
                              • 1590
                              #44
                              At first glance it looks like the rocker arms are in the wrong position...............but I know next to nothing about X-Flow Engines.
                              • max0815
                                • Aug 2011
                                • 676
                                #45
                                We tried a few things with a orginal roller cam the pushrods are correct. The one we have fitted is from burton power. Standart lift.
