so if these full monty big money duratecs arnt even keeping up with the pintos built in a shed by a 73 year old what chance have these standard £50 duratecs and zetecs got
Also don't forget most of the Harris pintos have got 190-215 bhp at sanspeed ( Which according to you lot reads 25+ bhp over ) so this means the 285 bhp duratec ( which should make 315 bhp at sanspeed then ) has at least a 100 bhp more power YET it still can't out run them !!!!!!!!! ..........
popcorn:
Bottled it did I. Dream on brother. Lets do this the proper way. Get the Harris's top spec drag car out and I will race it up the pod, with no changes. Then lets get the Harris's car around Brands or another circuit of your choice (without no set up changes). We will do a single flying lap, add the 2 times together and the one with the lowest overall time wins. No excusses then.
I said the track racers bottled it AGAINST mine not anyone elses , so provided they are N.A. mk1/2 escorts , use street tyres and don't weight less ( so lightweight specials with tracing paper for panels etc have weight added to match my heavy ROAD car ) then i'll race them around brands hatch and kick their arses up the drag strip . The offer still stands so bring it on ..........
who are these track guys that bottled it then gaz? i dont know any circuit racers with escorts that race on road tyres.
popcorn
this arguement is getting silly, what the hell is it about?
fact no 1, road cars are best on the road, they are not best suited to drag racing or circuit racing and will only do an avergae job at either.
fact no 2, any car set up for drag racing will be utter s###e if you try to circuit race it, as the biggest part of a drag race is the start the tyres and suspension will be too soft and wobbly to have any real corner speed, down the straights it will scream its nuts off and go nowhere the gearing will be too short, and likely to run out of brakes after a couple of laps.
fact no 3, as the start of a circuit race is only a very minor part of it and corner speed is nearly every thing, the suspension and tyres will be way too hard for dragging, gearing will also be totally wrong, as i dont recall too many atmo 2.0 drag cars needing 130mph top end, so most of a circuit cars best bits it corner speed and braking ability are lost in a drag race
fact no 4 swapping tyres around wont turn a drag car into a circuit race car or the otherway around
fact no 5 there is about as much point to this arguement as arguing tea is better than coffee or vica versa, it not just different.
i also doubt most circuit cars are as much lighter as you think gaz, they have far bigger fuel tanks, roll cages and brakes compaired to drag cars, they are also built to a set of rules which are fixed
anyway wasnt there something about rolling roads in the title of this thread?
Very well put Graham
IF people put as much time and effort into their projects as they put into arguing on this (and other) forums their projects would be finished much sooner and they could then be able put their theories about what's quicker etc into practice
Now what was the original question??
Well Dave done an impressive 12.3 today @115 i think. That was on a 3.7 diff also. More to come from that car i reckon,sounded sweet
Well we're not worried about circuit race cars anyway are we chaps ? So back to the proper cars at once then !!!!!!!! . Well a great day at santa pod today and a massive round of applause for the 285 bhp mountune duratec which managed to keep up with the pintos . It went well with a 12.3 sec at 110 mph on hoosier drag slicks at the end of the event . A very good show from this car as i never thought it would stay in touch with the sanspeed tuned 215 bhp 8v 1970's engines with carbs and a dizzy , but it did so respect is due .
He even managed to fook the axle as they had it in bits in the afternoon. I suppose thats what you get for trying to lay down 285 bhp through drag slicks using an english axle
It went much better with the 3.7 diff in it though , he was running 12.6's at 106 mph before they changed it .
Did you see Ron Harris's car launch with Andy Harris jnr at the wheel then ? It pulled a proper wheelie and shot off like a missile until he broke the selector roll pin in the gearbox going into third gear
what was daves reaction time on that run?
i noticed the harris' were doing it at 0.1/0.2
and in the first few runs dave was changing gear six times up the strip...
how much time do you lose each gear change?
well done to him for pushing forward the old skool ford scene
The clock only starts ticking when you break the light beam ( start moving ) so reaction times don't mean much . The more gear changes you make means that you've got less time on full throttle so the less changes the better . The problem is if you gear an engine too low though it won't get into it's power band and bog down . I think his gearing at the end was good , it launched hard and even beat Jaysons 2.3 pinto in first gear but was outgunned after a few seconds though .........
My instal so far is going to be around 3k.
Now i got a bargin coz my engine came with dry sump and tb's.
But you dont need a dry sump and can have a wet sump made for less than £100.
Change the rods, pistons and cams which can be bought for under 1500 quid and you should be pushing 250 maybe more.
So i reckon as long as you do some of the work yourself you could do it for under 5k
Incase anybody hasn't seen this 285bhp duratec install then heres a pic for you . DO NOT confuse this top spec motor and install with a normal ford scrap yard engine please because this one aint cheap !!!!!!!!!
are there any 285 bhp installs to a mk2 escort that are cheap gaz?
i'd love one
Yeah a stage 2 cossie turbo engine are cheap enough to install
and we all know thats cheating, so sorry kev
but 0-60 in 2.5 secs
Gaz i ran a 14.4 and a 14.6 in the shit bre nova with a standard xe with bike carbs.....what power does that make it bearing in mind it was my first ever go at drag racing and i left the launch control on a bit too long on pull off, and we are running marshal ditch finders with plenty of wheelspin. Anyways as promised i caned the shit out of a pinto powered rs2k with gp1 induction and a kent cam and shit, he reconed he was missing on one at the very end which is why i beat him, but i was already ahead at the 1/8th looking at the time slip (which is the bit that counts) i also shit the NMS tuned red s1rst with 200bhp off the line and his reaction time was 0.12s
1:0 to the nova :nana:
It also beat a harris car and i even missed a gear, it was a standard xflow fiesta though
And only one small breakage of the engine falling out on the rally stage as dan stripped the engine mount bolts out the block
Not bad dave , novas with 2 litre XE's always run about that time . Put the engine in your escort and then have a go instead and see if it's as quick instead of the full race mapped x-flow .............
Na i dont think its gonna last long enough
And it will go faster with my brother driving as i still showed some signs of mechanical sympathy
And dont worry the xflow will get a nice bre makeover in the winter maybe then it should be a lot quicker...and mapped and built by me
We will see, cant be any slower than the harris fiesta i raced with its 19.8sec pass
Well what do we have here then , a retromotorsport special out for a Sunday drive . No doubt looking for a track to lap and took a wrong turn somewhere !!!!!!!!
