well done matt,now you best get the 2nd oct booked off from school then for your 1st track day bitch
Nice work Matt! Get some pics up old boy!
Pics as requested
Nice But i prefere them in cream
thanks Guys !
I like it Mattlooks a lot meaner
tommy 2000
Love it matty boy, now get the tyre fitting jizz off the beads and get painting some bits black like the window rubber trims and all your chrome shit
^^^ ignore him listen to Dave !
looks good but as said get the shit chrome off the tub dude and lets av some satin black going on it matt.still say grey for the wheels and slam it more ffs
looking good
was AJ walking away in disgust in this pic after you told him your thinking of fitting a zetec
she looks sweet mate just needs a mexico front panel and boot spoiler to look proper cool
Totally changed the car with those revo's, Looks great
hay matt, just wanting to know wot the colour is calld as my estate is the same colour but has been resprayd and had 2 much black mixed in with the colour must get some pics posted up
It's Bermuda Blue mate You should certainly get some pics up
Wow, page 7
Well this is kind of me thinking out loud, but for ages now I've wanted/fancied putting injection/throttle bodies on the Mk2. My thinking is that it's the sort of thing that once fitted, can be interchanged with any engine. I would like a fairly simple set up...if possible...and without the cost escalating too far. I will start collecting together parts over the next few months.
I plan on basing the system around Motorbike Throttle Bodies (far cheaper than aftermarket 'proper' systems) although I know these do have some draw backs, the cost advantage outweighs them in my opinion.
My shopping list so far that I can think of for my Pinto is:
Suzuki GSXR 750 Throttle Bodies
ECU of some sort - I may spend more on this for a good one, perhaps Emerald?
Electronic fuel pump/filter (I believe the Sierra Cosworth fuel cradle slung under the boot floor should do the trick?).
I've read that I would need a swirl pot for the tank...may just get an Ally one and be done with it
What else? In my head I can do this fairly simply, but I feel in practise it is going to be tricky
I think you should spend the money on the bodywork first before it ends up as a major resto a few years down the line
But your list seems right, except i dont think you need the swirl pot as the std tank doesnt suffer too much from surge
Yep no need for the swirl pot But you will need to do a return to the tank. A fuel level sender from an rs will give you the return to the tank you need. You can pick it up Saturday
Looked nice on saturday, nice to meet you
Cheers Kev, you too
Took the car to HT's on Saturday afternoon to get Aaron to fiddle the carbs and as always he did a great job. Had a good chat with Broadmore, Jamie and Jon etc
I've decided after masses of peer pressure I should as Dave said get the bodywork sorted before it becomes a full resto job. The savings account has been started
good to hear mate are the plans just to spruce up or there any changes afoot
Hexham and District Motorclub
Just a spruce up - and by that I mean new sills, rear arches, probably a new front panel...new wings too while the cars in bits I'd get the engine bay done as well...which means I may as well do the boot too.
So not a lot
Worth the money though, think of it like an investment Its a nice shell so best to keep it maintained than let it fall apart, think of it as an expensive service on your engine, oil + filter, all new belts etc in order to prolong its life! Its all too easy to get carried away with bolt on goodies and let the bodywork go downhill to the point of it being a teabag, like mine was
Well, update time. The car has sat ignored all winter - only started twice in about 4 months
I dragged it kicking and screaming to Plough Lane for its MOT last week...and it passed Straight through with only advisories for the sills.
I've decided on giving up with the engine plans, it'll get Zetec'd in a few years I reckon, I'll just put up with it being painfully slow compared to the TDCI Mondeo Until then it's body work bit by bit as and when I can afford it. So once I've got the Mondeo back from Plough Lane (it's getting a scratch in the door/rear arch fixed because some Dorris scratched it in a carpark (me )) the Mk2 will go in to get the sills on both sides done and hopefully painted blue as oposed to the stonechip black that's on there at the moment. So not really an update, more of a bump for my thread and hopefully a little small spark of inspiration to get something done on it.
get something done with it lol summers coming.....
good lad matt ,at least your cracking on with it m8.tell terry to give me a buzz as well ive lost his number tell him
Bump
Right, well as ever I have changed my mind about the plans for the car a hundred times but now I've actually been proactive and done something! After a quick bid on eBay and a 2 hour drive to Nottingham to see Luz008 from here I now own this little lot:
[There should be about another 7 pictures here, but I can't make the uploader work, I'll try again with the rest on Sunday when I get back home]
2.0 Zetec, ported and polished head, fast road cams, ARP bolts, DTA E48 ECU and wiring, GSXR 750 Throttle bodies with ST170 manifold, full exhaust system, Polo radiator, coil pack, all the Retro Ford goodies, spare head etc.
Basically everything I need to pretty much drop it into the Mk2. I need to get hold of a fuel return for the tank, EFI fuel pump, filter, fuel cradle of some sort, high pressure fuel lines, expansion tank for radiator, rad hoses, I'll need to change the exhaust mountings to suit a Mk2 rather than the Mk1 the set up was in orginally, no doubt a few other niggley bits I can't remember off the top of my head. The swap probably won't take place until the end of July (when I'm off work for a few weeks ) but that gives me time to gather the other parts needed. So, if anyone has any of the above parts, do let me know!
about time you got on with something!!
least that bit of tarpaulin will stop any oil getting all over the place
excellent mate, its getting there
Hopefully be dropping the engine and all the other parts off at their holding pen tomorrow where they will stay until I get round to fitting it in a couple of months.
In the mean time I will be preparing to purchase other parts I need, starting with the fuel return situation. After doing some reading it would appear that the RS and Ghia Mk2 tanks have a fuel return built into them, I would assume from this that if I buy one I can simply swap my standard tank for the RS/Ghia one and that's the fuel return sorted?
Cheers all
Your right matt except its even easier you can just change the sender and you should be able to do it with the tank in place iirc also the sports had them
Popped into Plough Lane earlier and that's exactly what they said too Dave Anyone got one?
Had another go at uploading the pictures and they seem to have worked. Nothing too exciting, but it's something to look at.
My next question, can anyone recommend me a radiator header tank (I will be running a heater so will need the heater outlet/inlet) and is it worth selling the Polo radiator I have and buying the Polo rad with the extra outlet for the header tank?
Cheers, Matt
For the header tank mate I'd just go through all the newish Ford cars and see which one looks like it will fit well in the space you want to put it - given the size and variety of engines fitted to production cars you will have headers with any number of connections in different directions. PS don't forget the header tank has to be the highest point in the coolant system hahaha
Also worth a look is the gm (from a corsa b and others) and vw ones
looking good. should be fun with the zetec.
bmw rads have a built in header tank, not 100% if the inlet/outlet position is good for a zetec though.. also, i have a mk5 fiesta header tank here.
I can get pics/measurements of both if you like?
I'd be interested in the Mk5 Fiesta one... is it like this one? http://cgi.ebay.co.uk/FORD-FIESTA-MK...-/320500929094
Not sure there would be anywhere at the top of the cooling system to mount it. What are other Zetec users using?
I'll have a look out for the VW and GM ones Dave
Oh, hang about, maybe it would fit up near the bulkhead looking at this one? http://cgi.ebay.co.uk/fiesta-mk5-hea...item3cac26bbec
