My Mk2 Escort Sprint Car (A Vessel for frustration relief)
    Re: My Mk2 Escort Sprint Car (A Vessel for frustration relief)
    Originally posted by Tezza2
    i'll have to see how low it can go on the rear, depending on the shocks!
    It's not just the shocks that matter,you've got to make sure the link bar angles are right too.You may have to raise the front.
    TBH the best thing would be to get it professionally set up then make minor tweaks until you're happy,you need a good base line to start with then you can always go back if changes you make don't work
    • Tezza2
      • 595
      #47
      I totally agree, its a bit beyond me!
      i'll have to try and get the car up to garys at retro over the winter! the trouble is my 4 link has been badly fitted!
      which works against the handling!
      you still have to set the car up to the driver tho, thats why I have gone for softer springs recently, which has been more biased towards a rally setup, and I seemed to prefer the feel of the car, but its just a bit too soft!
      I've tried a few different setups on the front, compression struts with drop linked roll bars etc...
      I'm sure i'll get there in the end, I just need a bit of help!
        You set good times at Lydden on saturday
        I'd say you need to still go a little stiffer on the front though.
        Stop worrying about the link bars,the car can be set up around them or maybe the area where the bolts foul can be releived a little.
        • Roger Miller
          • 2897
          #49
          imho you should be looking at 4-500lb springs for use with slicks/slicky rubber, that should give the front end a fair bit of bite and if makes it slightly understeery then use the loud pedal to cure it
          1970s technology , again Graham
          putting harder springs makes it under steer more.
          having nose up makes it understeer.
          ...................I give up
          Take it Easy....
          Roger Miller
          Works-Escorts =
            i suppose it depends on where you start and how much harder you go roger,
            i can only speak from personal experience which has been on tarmac events with sticky tyres or slicks you want stiff springs, my old race car a bmw 2002 ( which has many simularities with an escort) just got better and better the stiffer i went on the springs, it used to run 700lb on the front, the current race car which is heavier up front is slighty better with 600lbs and absolutely yuk if i drop to 500's
            • Tezza2
              • 595
              #51
              Thanks
              • Tezza2
                • 595
                #52
                Many thanks Nick the car did feel better and more competitive.
                I have been looking online to see if there are any photos up of mine, just to see how it was handling!
                What happened with your steering?
                I'm looking forward to next year.
                  [quote=Tezza2;1397457]Many thanks Nick the car did feel better and more competitive.
                  I have been looking online to see if there are any photos up of mine, just to see how it was handling! look here:http://www.snappyracers.com/album/Ly.../IMG_7794.html If you email Jon he'll put up an album of all that he took of you.
                  What happened with your steering? TBH all I've done is unload the car so haven't looked at it,I'm stripping it over the winter anyway so I'll find out sometime but the fact that the adjuster nut on the tca has clouted the side of the x-member isn't a good sign,it could just be the rose joint that's bent though
                  • Tezza2
                    • 595
                    #54
                    Thanks for that Nick.
                    Well, I hope it was nothing too serious.
                    Have you decided what you are doing with the car next year yet?
                    • Tezza2
                      • 595
                      #55
                      There are some pictures at the following if anyones interested
                        http://www.snappyracers.com/album/TerryD/
                        Terry you're sposed to buy them before putting them up on here
                        • Tezza2
                          • 595
                          #57
                          OOps! Thats only a link to view them tho!!
                          Just waiting for prices!!
                          Are you going to Brands this weekend Nick?
                            I wanted to go on Sunday but can't really afford it.It works out bloody expensive with paying to get in and then for the stands etc,oh and the crowds drive me
                              Not in my experience of Tarmac Rallies, Sprints and Hillclimbs.....
                              • tom burgess
                                • 3590
                                #60
                                ive found that toomost escorts sit arse down,accept Trigs
                                sigpictommy 2000
