    • 25242
    a plus point about staying n/a is you wont need to change diff ratio which you certainly will if you go turbo, re gearbox, the t9 with a tranx gearkit you had wouldnt of really been upto it anyway
      Prodrives own M3, in their showroom;
      Another origional M3 rally car, rebuild for a customer by prodrive. There was also another one stripped to a bare metal shell but pics weren't allowed as it was being built right next to 2011's bmw mini clubman WRC car!
        Sneaky pics taken with camera at arms length under the bastos car;
        Front suspension;
        Rear;
          • 25242
          fronts have had the std "L" shaped lower arm replaced with a TCA and compression strut AKA escort, its difficult to see but like mine the ARB has had extra holes drilled in it, the picture also gives me an idea how i might move the ARB link to the strut (non m3 arb is linked to bottom arm) without wrecking my ledas
          rears have had the hub braced to the arm as thats were they bend, and the ARB mount uprated and rose jointed
            Nice one Dave! Those Mini's look awesome!
              Really, in the flesh it could just as easily be a Rav4 with a shortened DB9 bonnet, but we didn't see a finished car as it was elsewhere, sitting on its roof, in a ditch
              E30s were awesome though and looked better than new, no wonder the refurbs were £125,000. I would take a year off work and build Grahams for that , then i could give him £25k for his engine builds...
                What's with the boot lid?
                  That bootlid was standard equipment on the M3, I've often wondered if it was more than just an extra bit of styling.
                    I think it was to raise the rear wing, plus it ties in with the rear pillars which are completely different from a STD e30 and have a different rake. Only the doors and roof skin are interchangeable with the normal e30s
                      Was there some sort of regulation or homologation issue why they could'nt just fit a bigger rear wing?
                        Probably for Touring Cars.
                          • 25242
                          they put a lot of effort into improving the areo hense the thicker rear pillars and raised rear deck which also necessitates a shorter rear screen
                            Originally posted by Graham
                            initally i wont get a lot more power going M3 route as i simply wont have the cash to stick cams and stuff in it, but i recon i could achive 250bhp without difficulty with the potiential to add another 100 plus to that figure
                            Seems like your estimate is spot on Graham.......http://www.pistonheads.com/sales/1679894.htm
                              is that a second smaller red spring under the main black one? as i'm sure your springs just sit on the two rings.
                                • 25242
                                yes, its a helper spring
                                yes and no, my car currently also has helper springs fitted but mine are above the main spring, it doesnt make any real difference where the helper goes
