  • e21jason
    • Jan 2009
    • 6
    Graham
    I have a few s14 in bits and my e30 m3 is rhd and the stock manifold works fine, infact the birds conversion was just to space the downpipes out for the down link to pass through.
    If you need any radom s14 bits drop me a line
    Jason
      • 25241
      Originally posted by e21jason
      Graham
      Jason
      thats very interesting, i had a feeling that might be the case
        Originally posted by Graham
        i've got no choice, cams or no cams i'm going to have to machine the pistons more !
        edit:- crunching the numbers absolutely confirms it, to finish off at about 11.5:1 i need to loose about 10cc which is about 1.5mm off the entire face of the piston, it wont do the squish clearance any favours, but then again the turbo motor didnt have any squish and that coped just fine and it will mean the pistons arnt running right up into the decomp plate which is probably a good thing
        Could you machine a little bowl in the pistons and keep some squish while reducing the compression ratio at the same time. Is there any room to increase the volume of the combustion chamber in the head?
        TOm
          • 25241
          theres a bit to be had opening out the chambers head but TBH i dont really want to mess around with them so i can keep the option to use pukka race s14 pistons in future,
          the piston crowns arnt really thick enough to take a bowl being machined in them from memory there only 6mm thick in the middle, infact i was considering doing the opposite machining away more at the edges and leaving a small biscuit in the middle of the piston
            • 25241
            a few pics from hours and hours of porting.
            the std inlet port meassures 26mm dia a mere 70 % of the dia of the 37mm valve it supplies, when i did the last flow test i'd opened the test port up 2mm and gained massively in flow so i've high hopes for the second stab at opening it up, it took one hell of a lot of grinding to get them out to 30mm which is 80% of valve size, infact i've finished the head at least twice then gone back for more! the last time i did some work on the radius of the short turn, ive probably lost some low lift flow and gained at high lift, i have a feeling though that on the face of it i 'd loose twice as the valves at low lift twice, i think i'll only loose once as on the closing flank the ram tuning at high rpm should keep piling the mixture in, well thats the hope anyway.
            of coarse theres always the chance i've made it worse but what ever its staying as it is!
            std unmodified port
            • jonboy
              • Jan 2005
              • 1020
              VERY tidy, hope it works as well as it looks !
                • 25241
                you might of noticed no mention of exhaust work, thats because its not needed the std exhaust port out flows the std intake by 120% so unless i get over 180cfm (unlikely) theres no need to touch em
                  Have you got the exhaust manifold yet?
                    • 25241
                    i've been offered a couple
                    • mike105e
                      • Aug 2006
                      • 461
                      great work on the head.
                      i love the all the development work in this thread,. keep it up
                        Glad to see you are going 16v now, love the sound of a good 4 pot atmo e30 M3 engine, when you are finnished with the final version of this engine it would give a 2.5 millington a run for its money!
                        And 250bhp or so for now with a wall of torque is going to really get that e30 moving out of the corners
                        Best of luck with the new build
                          Graham, I've found the body kit ...
                          and a video
                            That would work Gary, don't think the wing is legal though Might need some 'Leepu' wheel spacers too
                            Does look good though, I just looked at the vid and the back of the car looks madder than the front
                            • cossymax
                              • 9034
                              Some excellent work going on with that head, when will you be fitting it and getting the engine dyno`d ?
                              Good luck with it fella
                              Old skool forever
                              Just don`t tell the wife
                              how much it really costs!
