Beautiful weather over in Belgium, 25 degrees, so decided to give sandblasting a go.
Not quite convinced bout this blasting, dirty work, lots of cleaning afterwards, and seals dont blast off that easily.
Gonna finish the rest with the trusty grinder.
Here are some pics (check out the massive filler job ...)
Tomorrow i will put some primer on the underside. Still need to figure out the mixture of primer and hardener. No clue so far
