    Hi guys and girls, gonna start a new thread here as the sierra we're building is going in such a different direction I think it warrants it. It will run in class D of the DMN with Andy Pipe etc and will be a great deal simpler and cheaper to run than it would have been in class A. Will be a competitive, very reliable package too if we can get it right
    Out came the V6 yesterday and in with a pinto that I have aquired as a dummy engine whilst my excellent new engine builder works on the real one. The dummy engine will enable me to fit all of the ancillaries around it and fully sort the engine bay, that way once the new one is done it will drop in and all be literally plug and play
    The brief spec of the car will be as follows.
    3 door motorsport shell, lightened as much as poss and running cossie suspension with leda coil-overs all round and hi spec monster 6 pots over 330mm discs up front (std cossie rears with race pads).
    Racing dynamics 9x17 wheels with Dunlop btcc rubber.
    Rough spec of the engine is a genuine 2.0 litre bottom end with wossner pistons and cossie rods. Injection head (if we can find one ) with big valves and a proven race profile camshaft.
    Pace dry sump will be fitted for insurance and it looks like I'll probably go the throtttle body route as I already have an injection set up in the car and want to run full management anyway.
    Gearbox will be a tranx type 9 (does anyone know if it fits the cossie prop?)
    Here's the pinto ready to start having the exhaust and ancillaries fitted;
    And a rough idea of the new look of the car, won't have a cossie grill or whale tail, but still have RS500 bumpers and arches. Will all get a little tickle from the painter once we're ready too, but wiil stay white and black
    In answer to the question re props:The splines are the same but I think the cossie prop's shorter than a type 9 one.
      • 25257
      hmmm drill a couple of new holes in the x member and move the engine back perhaps? saves buying a new prop and better for weight distribution
        I'll check it in the week while I still have a std type 9 there. If the bellhousing is like the V6 one then you can't go back very far before getting the gearbox out becomes a real problem with minimal clearance to the top of the tunnel.
        • Tezza2
          • 595
          you could fit three pinto's in there dave!!
          good luck with the car anyway....
            Cheers Tel, engine bay will soon get filled up though. I have an ashley 3 piece manifold and the longest inlet manifold going in hopefully so space will soon fill up. Also gotta fit a drysump tank up there
              You could go quick release on the bellhousing
              PS: have you seen this months fast ford mag?
              • mervhill
                • 1268
                Dave mate, you still struggling to find an injection head? I got mine from Temple Motors in Hertford, might be worth a try there.
                  I am yes, do you have their no.?
                  • mervhill
                    • 1268
                    01992582643
                      Cheers, will try them tomorrow. If not I'll borrow yours
                      • alladdin
                        • May 2005
                        • 9248
                        looking forward to this, sounds a nice blend of old and new
                        • angliaant
                          • Dec 2006
                          • 1841
                          good luck dave, i reckon itll be excellent once its done
                          thanks Guys !
                            How do you tell if its an injection head or not
                            I've got one here off an engine I got from a scrappy about 8 years ago, I used the 205 block for my cossie engine and just left the head in the back of the shed
                            • Dave
                              • 19588
                              Inlet ports are egg shaped on an injection head.
