GavinR's Mk2 Rally Car - FLY
    Curborough Sprint Sun 21st September
    Back to Curborough again for a 2 lap Sprint and after doing about 40 laps here a few weeks earlier I was hoping I'd learnt something
    Tony was out again and also Dean Maddock in his Pinto powered Mk2
    I knew I wouldn't get anywhere near Tony and should be ahead of Dean if I kept it on the track, so I thought I'd try changing up the gears without the clutch in an effort to gain some more speed
    1st Practice was ok at 65.22s with 2nd Practice better at 64.84s, nearly down to my best time of 64.72s set in July, I was having an interesting time trying to figure out how much to lift as I changed gear
    I had a gentle walk round the track during lunch with Alan and Juliet who were double driving the Mini, trying to work out better lines - Alan was keen to try and get the 1400cc Mod Prod Class record and move up the Overall Championship positions, Juliet was just out for some experience on her 4th ever event
    1st Timed Run and I found a bit more speed round the first left hander after our walk, only to arrive at the next corner a lot quicker than normal, scrabbled round the next few corners, down the straight, braked a bit too late to turn in for the 2nd lap, and reached the finish in 64.42s at 90mph Not using the clutch was giving me more acceleration down the straight but I still can't get out of the hairpin tidily, always spending too much time going sideways not forwards
    Meanwhile Tony set a storming 61.55s with Dean on 67.50s, Juliet did a steady 78.23s and Alan cruised in a lap early after hearing a worrying clonk from the front right corner round the first bend
    Before the next Timed Run, the Mini was stripped down to check the flywheel, clutch and everything else important on the front end but we couldn't find anything, so Juliet was told that the car was perfect and to give it a good test drive before Alan's last run
    2nd Timed Run and everything worked a bit better, but I could still only manage 64.37s, comfortably behind Tony and comfortably ahead of Dean
    Juliet was a couple of seconds quicker on 76.33s and Alan just went for it in his usual style, beating the record by 0.03s with 60.97s
    So another good day out, but now there was no way I could beat Tony in the Championship with just Prescott to go the following weekend
      And Curborough's in car
      http://www.youtube.com/watch?v=xxcpo_SzuEoYouTube - Curborough Sprint 21/09/08.
      • Dan
        • Aug 2006
        • 4378
        #243
        nice writeup again gav
        and it sounds like you need to do an Andy and get some arches and wider rubber on there
          No arches, but definitely some wider rubber for next year
          This year I've been running 7's and they're pretty much worn out now, so I'll get some 8's for next year's season
          Other than that Fly will be going on a diet and another winter rebuild as there are a couple of cracks that need sorting
            Prescott Sun 28th September
            This was the final round of the Midland Speed Championship of the year and I was looking forward to driving Prescott for the first time
            I arrived very early and had a gentle walk up the hill which looked very interesting with a good mixture of corners
            1st Practice - the start was delayed by an hour as we waited for the fog to lift, but the hill was nice and dry. I had a steady run up the hill in a time of 53.97s, Fly trying to go straight on at every corner didn't do my confidence any good, but a lot of people had the same problem due to the track being cold
            And even Gary Thomas, recently crowned Midland Speed Champion for the 3rd year in a row, went off in his Lotus Elise on the last corner, sliding 40ft down a grass bank into some bushes but the only damage was to his pride and the rear diffuser
            2nd Practice - the sun was out and the track giving a lot more grip, I pushed on a bit to finish in 52.32s, a lot better
            1st Timed Run - off the line reasonably well in 2.56s, not as much grip here as some hills I've been to, under the bridge at 61mph and into the first hairpin, Ettore's, in 15.43s, well ahead of my practice times, up to the steep hairpin left at Pardon, attacked the Esses a bit more and Fly turned in well for the last corner, Semicircle, so I could accelerate earlier, drifting gently on the way out and crossed the finish in 51.02s, another good improvement (but still 2s off Tony's Renault 5, but he'd been up here a few times before)
            2nd Timed Run - hoping to get another 0.5s quicker, I got a good start only to be Red Flagged at the bridge after a TVR lost all gears near the top of the hill, so I was directed to continue slowly round to Ettore's, back through the crossover track towards the start, back into the paddock and lined up for a re-run
            Off I went again, confident my tyres were nicely warmed up by now, 2.48s off the start, lifted a bit early under the bridge at 60mph and into Ettore's in 15.32s, tried to brake late into Pardon and again for the Esses, and got a nice drift round Semicircle again to cross the finish in 50.14s a lot better than I expected
            So another enjoyable event to finish the season with, I finished 11th overall in the Championship (Tony was 5th and Alan 2nd in his Mini ), 2nd in Class behind Tony, 3rd in the Consistency award (the difference between your 2 Timed Runs at each event counting for this one) and comfortably won the Classic Ford class again ahead of Windy who only did 3 events
              And the final bit of in car
              http://www.youtube.com/watch?v=LGTDeFkObDEYouTube - Prescott Hillclimb 28/09/08.
              • kosingcurry
                • 599
                #247
                Nice writup Gavin, I was at Prescott just last weekend and set a new class record. 47.54!
                  Nice write ups as normal Gavin, and well done on another first... be care full though as i think Windy and Matt are doing all the rounds next year, Matts even changed Jobs so he can get weekends off
                    Good, always more fun with some other Escorts out
                      #250
                      Only if there's a Rally Car class
                        I dunno Glen .. at every round of the Midland speed championship theres a class custom made for Matt and Windy's car .. infact it was Windy's idea, you can even compete and beat your brother in it ... and you may just do it,
                          #252
                          Yes yes I know, the old ford championship. I knew you'd bite!
                          • gonk12
                            • Jul 2008
                            • 94
                            #253
                            hi i'm new on this site, just read the whole of this thread can only say brilliant writing and congrats on the last few years driving, looking forward to more. good look.
                              Not a lot going on this month but I've finally fitted some new wheels studs to the front hubs - Fly was still running the studs I bought her with, std length Mk1 studs which aren't that sensible when some of my wheels need spacers
                              And I found some nice pics of Loton Park
                              May 2007 - My 2nd event there
                              April 2008 in the snow
                              And July 2008, the day after Fat Albert
                              • Tazman
                                • Feb 2008
                                • 76
                                #255
                                Nice pictures Gavin
                                Nearly lifting a front wheelin the last one
