four door mk2 road rally project
  • danknight72
    • Nov 2011
    • 584
    #106
    Re: four door mk2 road rally project
    Removed the fuse box and fitted a new blade type fuse box mounted underneath where the old one was so didn't have to lengthen any wires. Made a stainless cover for the hole.
    • danknight72
      • Nov 2011
      • 584
      #107
      Repaired near side rear wheel arch today, started off with this
      Ended up with this
      • danknight72
        • Nov 2011
        • 584
        #108
        Repaired off side wheel arch and inner arch and closing plate
        • mk22door
          • Jan 2014
          • 59
          #109
          Fantastic build, good work!
          Love all the little home made touches, it's going to be an excellent car
          • danknight72
            • Nov 2011
            • 584
            #110
            Thanks mate, finished the outer and inner wheel arch now and a small repair to the tank well.
            Going to attack the lower rear panel now
            • danknight72
              • Nov 2011
              • 584
              #111
              Drilled all the spot welds out and removed the old back panel it wasn't that rusty but was bent to buggery!
              • tombda
                • Aug 2014
                • 11
                #112
                keep up the good work
                • danknight72
                  • Nov 2011
                  • 584
                  #113
                  Cheers mate, rear panel is now on fully welded
                  • danknight72
                    • Nov 2011
                    • 584
                    #114
                    My old bug on the tour of cheshire 2011
                    • mista weava
                      • 992
                      #115
                      Nice thread mate.
                      4 doors will be seen more and more in competition as the 2 doors thin out.
                      www.rallycarsforhire.net
                      • lukem30
                        • Jul 2012
                        • 408
                        #116
                        Great thread, your car seems to be having all the same repairs as mine needs, it's nice to see all the photos of the welding to make sure I'm doing it right.
                        • danknight72
                          • Nov 2011
                          • 584
                          #117
                          thanks luke,im toying with the idea of going xe like yours will do a few road rallies see how the 1700 crossflow goes
                          • lukem30
                            • Jul 2012
                            • 408
                            #118
                            The xe has been great, I think you would struggle to get the same sort of power out of another motor for the same cost of the xe convertion, and if it goes bang it's just a case of replacing it with another pretty cheap standard motor.
                            • danknight72
                              • Nov 2011
                              • 584
                              #119
                              Ground all the welds down on the back panel, going to get a thin skim of filler before some etch primer
                              • danknight72
                                • Nov 2011
                                • 584
                                #120
                                After a lay off to fit a new kitchen back on the escort
                                Fitted spring hanger skid
