Hi. I have a mk1 escort running a mk5 escort RS2000 engine. I'm doing a rally on Saturday so have put some Yoko 21's on the front and Toyo 888 on the rear. When I turn in a tight circle and boot the throttle it feels like the rear is lifting the inner wheel. The front suspension is compression strut with standard height 190lb springs (as recommended by West Wales Rally Spares) with unknown struts and the rear are 146lb leaf springs with 40 mm blocks, spax turret shocks, tramp bars and atlas with gripper LSD .
Is the front to soft? Is the rear to soft? The car is sitting high to reduce damage underneath, but my brothers mk2 is higher and he has no such issue. It only seams to do this if I have good grip on the rear. With crap tires on it just slides. It nearly went over once on a hairpin with slicks on.
Any one got any ideas.
