Escort Suspension issues
  • max0815
    • Aug 2011
    • 676
    #16
    Re: Escort Suspension issues
    We drove on German Masters Slalom yesterday and had the same problem as jonsey. I talked with someone who watched the race and he says we are wo soft with the leaf springs.
    Has anybody tryed to use leaf springs and a coilover spring together in the back??
    • sholdowa
      • Oct 2006
      • 521
      #17
      yes, it's certainly been done with 4 links and slippers.
      Edit. And yes it was an improvement!
      • max0815
        • Aug 2011
        • 676
        #18
        Could anyone tell me the advantage of those slipper springs?? Just saw them the first time.
        I think I“m going to fit a second spring from a stock escort to my single on for the next event.
        At Sunday the Escort drove like a Tarmac Escort should:
        One wheel in the air
        Can“t post the picture http://www.rennfotos.de/galerie/weit...013/index.html 7.row Pic DSC_5768
          slippers are needed if your going to keep leaf springs when you 4 link, otherwise the rear suspension would bind and not be able to move up/down properly.
          • qcadta
            • Jul 2007
            • 258
            #20
            how much travel/droop have you got in the rear? plenty of clearance between chassis and diff? looks like a hair raising issue.
            • jonsey
              • Feb 2011
              • 147
              #21
              Not sure how much drop. I can jack the axle up on on side and it goes right up in to the arch without hitting any thing. I've only got 40mm lowering blocks on rear so it sits quite high, but with 2 spare wheels, full tank and tools the rear is sitting lower. During the Targa Rally I had no issues, but did have rubbish rear tyres on and drove with a lot more committment than you do on the road, so the rear end broke free. (I think).http://daphotographic.co.uk/kidwelly-targa-2013/# Some photos from the rally
              • rhodrievans
                • Feb 2010
                • 142
                #22
                If youd like you can pop up and compare your setting with our mk2 rs2000 sounds like the same setup but we don't have compression struts
                • jonsey
                  • Feb 2011
                  • 147
                  #23
                  Where are you based Rhodri?
                  • rhodrievans
                    • Feb 2010
                    • 142
                    #24
                    Carmarthen just seen again you have turrets but could always compare
                    • RS500Larsen
                      • Aug 2012
                      • 11
                      #25
                      Just a quick thinking... Check your traction width in front and then in the rear. If your car is too soft in the front with a more narrow traction this will occure. You will always get a better handling when your car has a wider traction in front
                      • jonsey
                        • Feb 2011
                        • 147
                        #26
                        The front is probably just a bit wider than standard. The rear is running an atlas which is only 47.25" flange to flange, so the rear is definately narrower at the rear. On the targa rally I ran 7" wheels alround, but when it nearly tipped I was running 7" on the front and only 6" on the rear.
                        • max0815
                          • Aug 2011
                          • 676
                          #27
                          We tryed a harder leaf spring on the weekend and the car was nearly undriveable. It runs on two wheels in every corner. I really don“t get it where this is coming from
                          and from another event http://www.youtube.com/watch?v=Qem8vxFNS3Q from 4:29 on
                          • freddy686868
                            • Jul 2010
                            • 4689
                            #28
                            This is how my more door cornered on a track setion at castle combe
                            The spec of my car is
                            Road leagal hankook slicks all round softs on the front mediums on the rear.
                            Front end
                            2.25 coilovers 180lb springs
                            Long tarmac spec dampers
                            Twink arb
                            Double width kit
                            Rear end
                            Anglia van axle plated diff
                            Mk1 escort multi leaf springs poly bushed
                            Bilestien rear dampers
                            It corners as it should really although if i was to do more track days the front end would need stiffer springs. I hope that gives you something to compare against because from what i can work out your set up isn't far off the same as everyones.
                            • hawk1903
                              • Jun 2009
                              • 956
                              #29
                              Since you do not have the front ARB fitted, You would definetely not go lower than the 200lbs springs in the front, even 225 lbs may work well. 190lbs without the ARB is very much on the soft side and as stated above, it is probably causing a dipping towards the outer front corner. For the rear, nothing is wrong with the 146 lbs leafs in my opinion, I always like to rear end as soft as possible for better traction and grip.
                              My mk2 pinto engined car is configured for the tarmac rallies as follows ;
                              Fronts suspension : Twincam ARB, 300/70 short Blisteins 225 lbs 2.25 springs
                              Rear suspension : No leaf springs, 6 linked, 140 lbs springs on the non-cannister type Reiger single adjustment turret shocks. However, I could have used probably 150 lbs springs but not more than that. Of course, having a Reiger shock is a big advantage even over the typical turret Blisteins.
                              Tyres : This season we have used DMack rally slicks and they were really good
                              • jonsey
                                • Feb 2011
                                • 147
                                #30
                                Max0815 :- is that high speed driving or slow? It looks quite quick, mine only seems to lift on slow tight turns. Looks bloody scary though.
                                Freddy686868 :- Your car rides pretty high like mine. It seems to lean a fair bit too, but don't know if mine does the same as all the photo's I have of mine is slower speed turns where it sits quite flat as its sliding. Looking good fun though. There is a track day with Kidwelly Club at Pembrey coming up if your interested.
                                Hawk 1903 :- I might try 225lb on the front when funds allow, but I didn't want to go to hard as didn't want to induce understeer, but then some people are running with over 300lb on the front.
