Escort Suspension issues
  • jonsey
    • Feb 2011
    • 147
    #76
    Re: Escort Suspension issues
    I think it's back on the gocart track this time. We've done a good few on the main circuit as well and also a combination of the both. It makes a nice change swapping things about. I think I prefer the main circuit as we use cones instead of tires so less chance of damaging the car, but if you do demolish a cone you get to pay £5 for its replacement and you get a 5 second time penalty for everyone you touch. Encouragement to keep it clean. I think a couple have pulled out already.
    • jonsey
      • Feb 2011
      • 147
      #77
      I did the Motorkhana down Pembrey Circuit on Sunday. The car suffered from fuel surge all day. The strange thing is it didn't do it at all during the last 2 events. I hadn't brimmed the tank this time but when I added more fuel it made it worse. It's running a mk1 3 litre capri tank, through a low pressure filter, into a swirl pot then through a pump and high pressure filter. The return goes into the pot then a relief goes of the top of the pot and back to the tank. Does it need a low pressure pump to feed the pot? Anyway I had 1st in class and 3rd overall, but on the last run I smashed it into a couple of lorry tires and bent the front panel and wing. In my temper on the next chicane I clipped the back on the tire wall denting the lower rear quarter and destroying the rear bumper. It's off to get repaired tomorrow.
        yes you should use a low pressure pump to feed the swirl pot
        • jonsey
          • Feb 2011
          • 147
          #79
          Cheers Graham. I'll have to sort one out then.
