  • madragon199
    • May 2010
    • 1139
    #91
    Hi matt the axle of a mits /shogun...needs massive lightning..but perfect width for me come standard limited slip//unbreakable shafts /disk braked...got to convert it to 5 stud but it will fit my wheels..
    Its just a pinto...with a twist...i built the head with down draught ports. 8 injectors....variable velocity stacks...46mm throttle bodies(bike) ..46mm and 37mm valves...
    the bottom end is waiting for pistons to be made...i had the rods made long stroke 5.73" but i also stroked the crank...this means the pistons will be only 21mm above pin (prob only room for 2 rings)...there is a build thread on here if you have a week to spare reading it..ill find the link and post it up...cheers mark
    • madragon199
      • May 2010
      • 1139
      #92
      i think that will work..if not its called Down draft b.v pinto with variable velocity stacks shed build adventure
      cheers mark
      • Matt75
        • Mar 2011
        • 797
        #93
        Hey Man, how could i forget your epic engine build. Apologies. My Pinto is due to be dyno'd in a few weeks now and should see high 180's or hopefully low 190's on 48 DHLA Dellortos.
        • madragon199
          • May 2010
          • 1139
          #94
          that will be plenty of power..and hopefully reliable...your running quite a high diff(from memery) so you will have awesome acceleration through the gears...
          what cam did you chose ?
          cheers mark
          • Matt75
            • Mar 2011
            • 797
            #95
            Yeah, the guy building oy does race pintos so hes known for reliability.
            The cam is a custom grind but similsr tona Wade 520x .490" valve lift and 311deg inlet and 310 deg exhaust and is around 254@50.
            Yeah, the diff is a 5.3 which is ridiculous dk I'll get it rebuilt to 4.4 or thereabouts
            • JudderMan
              • Feb 2017
              • 21
              #96
              This is awesome and just the sheer speed you've gone through so much work in little time. We'll done mate. Really looking forward to seeing and hearing it go (videos please).
              Sent from my SM-A500FU using Tapatalk
              • Matt75
                • Mar 2011
                • 797
                #97
                Carbies all built up
ID:	2020766Click image for larger version
ID:	2020767Click image for larger version
ID:	2020768Click image for larger version
ID:	2020769Click image for larger version
ID:	2020770Click image for larger version
ID:	2020771Click image for larger version
                • Matt75
                  • Mar 2011
                  • 797
                  #98
                  Pics are all arse about....
                  • Matt75
                    • Mar 2011
                    • 797
                    #99
                    Engine building back on track
                    • Matt75
                      • Mar 2011
                      • 797
                      Now painted
                      • Matt75
                        • Mar 2011
                        • 797
                        • Matt75
                          • Mar 2011
                          • 797
                          Engine should be dyno'd in a few weeks hopefully...
                          Starting back on the car next week. Can't wait
                          • madragon199
                            • May 2010
                            • 1139
                            nice work as always...engine has to be green..i couldnt decide on a color for my block..i went through zakspeed green,orange, silver..ended up with deep pearl blue..but still want to look zakspeed ..maybe gold...looking forward to the car updates..cheers mark
                            • Matt75
                              • Mar 2011
                              • 797
                              Hmmm, i didn't think about gold.
                              Matt
                              • Matt75
                                • Mar 2011
                                • 797
                                Sorry for the lack of updates. Progress has been made though
                                Engine is finished and will be on an engine dyno next weekend. Hoping to see high 180's and maybe low 190 hp but we'll see. It'll be mated to a W58 Supra gearbox.
                                Few pics
