GavinR's Mk2 Rally Car - FLY
  • tim
    • Apr 2004
    • 3187
    #46
    look like FLY lasted a good few years,only fair for abit of tlc now,only just noticed you holes for filler caps on both sides any reason to this
    also got any more pics and spec of the mk1 mex?
      I used to run 2 standard fuel tanks in the boot before I could afford an alloy one - I ran out just before halfway on a Norfolk Road Rally and this was my solution. Used to get funny looks in petrol stations though
      Mexico is a genuine Mexico, slightly tuned engine on standard carb, standard brakes, suspension and gearbox, English axle with 4.4 LSD
      Then just the usual safety features, cage, harnesses, sumpguard, spotlights, etc
      Still pretty quick down the lanes though
        Update from last week
        Bad side repaired
        Trial fitting of wings and front panel
        Got everything fitted properly, wings bolt on with 19 bolts, and undersealed everything in sight
        Fly was delivered back to paintshop on Sat and should be collecting this Thursday night ready to bolt everything together this weekend. First event is Curborough on 22nd April pray:
        Must find one of those 3 timing struts I've got as well - shows how many Sprints I've turned up to without one and had to make one in a hurry
        Also picked up my new axle last week, together with a new WCXM, strut brace, steering rack, starter motor and some fully adjustable top mounts from Mac
          Picked Fly up last night - lovely and shiny for the first time in years - looks a different colour which just shows how much it had faded over the last 12 years since the last respray
          Plan is to have it running by Monday night pray:
          • tim
            • Apr 2004
            • 3187
            #50
            good lucky cant wait 2 see FLY all done
              Well Fly's not running yet
              Did find some tyres though
              Didn't realise I'd collected that many over the years, and about 50 of them are on rims, which is why I've narrowed the axle instead of buying new rims
              Back end back together with some 20/53-13 TB15's - fits perfectly even on full compression
              And the engine's bolted in on the new WCXM and rack, just needs all the plumbing and wiring, and a gearbox might help
              Looks like I'll be out in the shed a few evenings this week, 12 days to go to Curborough pray:
                Just started up the cossie
                Nearly there now, just the brakes and a bit of suspension work, fit the doors, seat & harnesses, lights and find some decent slicks to run on
                  well done on the turnaround...
                  (how was the starter?)
                    Turned the engine over as if there was no compression - very impressed and small enough to remove with everything in place
                    As long as Steve's posted the alternator out to me, or is going to tomorrow, I'll be happy
                    Only ran it for a couple of minutes to check there weren't any leaks, couldn't be bothered to make another alternator fit so now water pump running either, and it was a bit loud with just the manifold fitted
                      Thats what i like about those starters.. slips in easily and comes out easily. And your not the first to check wether you've forgotton to put the plugs in
                      I belive it went before the weekend , maybe saturday as he pointed to a label and said ............
                      "well go on then, you pronounce where he lives then"
                      I gave up
                        I gave up
                        I just make it up as I go along!
                        Anyway it's sitting at home now waiting for me to fit it tonight, so you can thank Steve for me
                          #57
                          superb thread ! just found it and im impressed.the road rallies seem to have got rougher since the 80's ?
                            I'm not sure if the road rallies have got rougher but I always seemed to do better on the rough ones
                            Since the introduction of the 30mph average, a common way to slow people down is too use a lot of whites or farmyards, although in parts of Wales and Devon the roads are so nadgery there's no need
                            • GP4
                              • 1607
                              #59
                              Originally posted by GavinR
                              Since the introduction of the 30mph average, a common way to slow people down is too use a lot of whites or farmyards...
                              Or have a control or code board every 300 yards...so you only ever get up as far as 3rd gear before having to throw out the anchors again!!!
                              • Andy Rich
                                • Jun 2006
                                • 52
                                #60
                                You weren't out on the Greenleaves as well were you by any chance?
