Ford Taunus TC2 - now Trackday car
  • Arieke
    • 442
    In 2014 after a race my back gave away. After been home for 10 month nothing got better so, the surgery took place. in noverber 2014. The doctor told me to keep off racing for at least and of august. Because season is almost over then, I didn't race in 2015.
    In 2016 i tried to get back to Rallycross but that didnt go wel. So after what thinking and still wanting to drive this car, I did a switch to Circuit racing. But one big difference. No competition. So only Track Days for fun. the plan is to get the car oke for Zolder and then go further and further, Plan is next year Spa Francorchamps.
    The First outing on Zolder, i didn't change anything on the car. Just like it was. Couple of problems, the 5.14 atlas axle doesn't have a good topspeed. So that needs changing. The other problem was that my engine keeps overheating with 2 fans i would think it would be good. On Rallycross track it was fine.
    I did some changes. I made a scoop in the left rear window for hopefully more cooling for the engine.
    The other change i did was the switch the 5.14 atlas with a 3.78 koln axle. It has also a 100% locker in it. I had a brace for my atlas axle so I made one for my koln axle. Was a fun job to make. Its the same thickness 8mm. I orderd a couple braces actually the same as on a atlas axle. The tubes are the same. So less work :-)
    The pink is a left over painting from ex girlfriend and was to lazy to change it.
    The other thing i changed was the exhaust to a japspeed exhaust from a skyline :-)
    The last outing was in april. I had a blast.
    The koln axle did well. The car did a higher top speed then it had in its good old days! 146km/u with this axle it could do 203km/u
    I have been using Harry's Laptimer and my best lap time was 2m16!! Awsome. My 2.0 ohc Ford Sierra i did 2m32 so Taunus is alot faster.
    The overheating problem is still present. The scoop didn't do the trick. So i will need to do something else.
    • Arieke
      • 442
      • Arieke
        • 442
        Hello everybody,
        After some trackdays on Zolder i was sold. I decided to fix alot of problems over the winter. Do some bodywork because the car is a little bit rusted.
        The car still had problems like overheating and the dizzy broke for some reason. I got a other one but the turn in a other direction in a escort so it din’t work in my setup. So i binned it and finaly installed a edis setup on my engine. I make a curve from my old curve setup and It pulls like never before. The engine came to live!!!
        So first the rest, more changes on the car yet again. A bigger tank, Rallycross didn't need more. So got a tank from a Trabant of 25 liters. So a bit better.
        Because the engine kept overheating i finally put the radiator back up front, but because the engine is a little bigger then a Pinto i cut out some metal. On track test were verry good actually to good. The engine can't warm up past 70° Celsius, so blocked some off, so the engine could warm up. Will be making something out of plastic, because paper won't work in the rain.
        I gave the trabant fuel tank a respray and with in
        On the track they want to have lights in the cars. When i did Rallycross the car just needs brake lights. I in installad some head light and made the tail lights work again. I got some led for the head en taillights so my battery doesn’t suffer from the draw from halogen. There is only a night race in december and the track is well lighted in the dark. The full beam works also. The little fog light aren’t on the car anymore. Because the dont really work and it doesn’t look nice.
        • Arieke
          • 442
          I will make the picture a little bit smaller the look way to big
          • Arieke
            • 442
            So the big winter project,
            It started because i would like to do at least every year a big circuit. And the my car needs to looks better then it does now. So this year the plan is to go to Spa Francorchamps. 2019 we hope to go to SilverStone, when Ford Fair takes place.
            After the bodywork the car would need a respray, so looked on the internet and yes I didn’t find anybody racing a Taunus. My dad found a nice paint job on a Taunus. I loved the looks and a simpel desgin, oke i don’t have the wheel arches.
            First off it started with the rear panels. They had 3 layers of metal. The previous owners just stuck more metal on the car. Got that fixed. It needed both sides. I even made more room for my exhaust so it sits more straight under the car. But i don’t have a picture of that.
            The left side was so worse, I said it had a bit of rust... It had alot of rust. It needed a new wheel arch and i made it myself. I got some help, but it started life as a flat sheet. Me verry happy, and yes i found that the wheelarch was a 3 layer piece, the origenal piece was still under there. In front of the wheelarch the hole was a start, but i started cutting till I got 1 sheet metal. So its like 3 times bigger.
            I got a new door for the car, because mine was dented after some rubbing,
            When i installed the mt75 on this car the tunnel wasn’t big enough, so i just cut out some stuf and i was done. I just covered it with some plastic and was happy. But even that was going to be fixed. I didn’t fix this a friend of mine made this so i don’t get the credits for this, but its looks awsome.
            So got everything fixed. In november i was allowed to have some place in a shed from a mate. I said in the beginning, i will just need it for some bodywork and then a respray. Finally in april i got the car done and resprayed. It look so long. Oh well its done and looks nice. I got even all my wheels sprayed to look nice and shiny. The final thing like stickers still has to be done.
            So i hope you guys like it. After Spa i will be changing the 3.78 ratio with a 4.1. And a tune up on the engine because of the ecu now on the car.
            The next big thing i want is in from a good suspension. So hopefully ajustable shocks and better springs to make it stiffer.
            And just maybe some disk brakes in the rear. Got them already but need a verry good clean up.
            But first some racing and having some fun.
              • 25258
              excellent thanks for the update
                Ford Taunus TC2 Rallycross
                Loving this thread 👍
                Quote of the day " paper doesn't work in the rain " 😄😄
                • Arieke
                  • 442
                  I had some free time this weekend. Did some adjustments on the car. But the best is for now.
                  Here are some pictures from the car with stickers on and the wheels on. Hope you like
                  Sorry for the fuzzy camera but that happend when the pictures decreased in size. But you get the big picture. I still need to put the safety stickers on, they need to arrive first.
                  The interior fan was broken and since you can't buy them new. So I just binned it and used a 120mm fan from my pc and installed it where the other one was sitting. It works!! Awsome! Only it doesn't move alot of air. So orderd a 200CFM fan. Hope it does the trick.
                    • 25258
                    nice one, good to see another project/race car being worked on again
                    • Arieke
                      • 442
                      a link from youtube, from me driving on Spa Circuit. No sound because you here de stupid wind
                      • Arieke
                        • 442
                        My last Track day from the Year. oke it was 8 december.
                        This year i noticed that my brakes aren't that good. I did a upgrada couple years ago, capri ventend disks and granada calipers and granada M/C. So this winter i'm gonne try and upgrade the brakes again for a bit more stopping power. I want the keep my 13" wheels so not alot of choice. So I found capri sport and they have a kit for fitting 260mm with 13" wheels.
                        So 260mm disk and a set of mondeo calipers will be the new brakes in front and finaly the rear drums wil go. Installing fiesta disks and fiesta calipers in the rear.
                        I will update here when i finaly get some parts and need to machine some parts to fit. But bad time to do stuff these days :-)
                        And hopefully better brakes and faster laps :-)
                        Oh yes i forgot, installed in front a set of lowered ford Transit MK4 spings in the front of my Taunus and wonder above wonder. they work a bit better. alot firmer ride better for the Track anyway
                          I don't think mondeo calipers fit ( unless kit changes) you need xr4 / Granada/ s2 escort turbo from memory.
                          • Arieke
                            • 442
                            wouldnt know. Ordered the bracket kit from caprisport in beginning of december and still waiting. I hope they fit :-)
                            • Arieke
                              • 442
                              Had some fun on the Rolling road. My 2.3 engine still lives. Not to bad for a engine that i build on my own :-)
                              My 2.3 I4 scorpio engine had 145hp when it came to life. When I gave it a nicer 2nd life I did some head work with a rs2000 head en FR cams. A little bit cr boost from 10.0 to 10.7 :-). And 45 dellorto's and megajolt.
                              And after 6 years Racing and all the overheating it has 195hp and 242nm @6200rpm. So Boem yes still nice 50hp extra!
                              Got some advice from the person from the rolling road. Remove the big rear spoiler, kill to much speed. Use a rear muffler from a rs2000 mk2 escort, less noise and they are good and lose the jap speed exhaust.
                              The other thing he said would make more power Raise de CR. 10.7 is to low. I could see over 200hp.
                              So next month i will do some testing without the spoiler and see how it goes.
                              I told him i was going to build an other engine. maybe a RS2200 (2.3 block with 2.0 crank) and yes higher CR and a little bit wilder cams. Dunno yet. I will see the 1ste of may on Zandvoort in Holland
                              • Arieke
                                • 442
                                So the 1st of may past. I had a blast [MENTION=31442]zan[/MENTION]dvoort.
                                On the rolling road my car did 210km/u and for some reason when i was on zolder 150km/u was the cars max speed. So with the advice from Arno for RR, remove spoiler. So I did. I hit 172.8km/u with my Taunus.
                                And the brakes are awsome!!! landrover M/C front 260mm with modeo calipers with yellow ebc and read fiesta front brakes and disk with green ebc. from 172 to 80 +- 100m I checked sessions from zolder with older brake setup 150 - 60 +- 180m.
                                So we have to see next time on zolder how the top speed wil be.
