    Re: Paul Alex's Honda-powered tarmac rally Escort
    Why did you leave the engine standard? Is it just powerful enough as it is? Won't the Duratecs give you hard time (seems like no)?
    • Hoogi
      • Jul 2008
      • 1590
      #17
      Paul,
      Absolutely love the Pic of your MKII Merv's has put up on this thread...............
        They are quite powerfull as standard... and look at the results, fastest times on the stage, or in other words..balanced..
        And then theres the bonus of if it goes puffft ... you can grab another engine from the carpark
        • jonboy
          • Jan 2005
          • 1020
          #19
          Not bad for a boat anchor lol
          Car looks great in the pic Paul
            There sure are a lot of S2000's in UK.
            They "cheap" enough to keep a spare? That would make sence.
            Was it 240bhp out of the box? Does theafter market ECU and ITB's improve it still? I guess it matches up to most tuned duratecs?
            How about the box? STD? Does the STD engine and Box mate nicely ratio wise for rallying? Only CWP needs to be changed.
              Why boat anchor?
              • jonboy
                • Jan 2005
                • 1020
                #22
                Why boat anchor?
                It weighs a fair bit ! Great engine though.
                As for your previous post a aftermarket ecu makes a LOT of difference in terms of getting more midrange power, throttle bodies also help a little too but overall peak power isn't that much of a increase over standard, approx 255hp from a claimed 240hp standard power.
                As Gary said though its a cheap engine to replace if it ever fails, which tbh is unlikely.
                As for gear ratios :
                Probably best to keep this on topic and start another thread in the correct forum if you have any other questions.
                  Sounds sensible.
                  Didn't realize I was so off topic though.
                  • jonboy
                    • Jan 2005
                    • 1020
                    #24
                    Thats my fault as I thought it was a discussion about Pauls first event not the car itself.
                      #25
                      I believe the increase is a little more than that, around 270 is the figure in my head. Paul has a Quaife G60 gearbox.
                        • 25249
                        #26
                        from what i've heard in terms of peak power on an otherwise std engine ecu and throttle bodies add nothing more than a couple of bhp at peak power but do improve the midrange
                        • jonboy
                          • Jan 2005
                          • 1020
                          #27
                          That is very similar to the setup that Paul is using, I'm running a slightly different set of throttle bodies but from what I gather the gains are nigh on identical.
                            Very impressive first outing, shame about the off
                            Shows all the hard work was worth it
                            • para144
                              • Jan 2006
                              • 1075
                              #29
                              saw the photo of the car in the ditch in this weeks Motorsport news, shame to bump it but sounds like a strong start!
                              • PaulAlex
                                • 1551
                                #30
                                270?!? In my dreams Glen As has been said elsewhere, 255bhp is the figure that RED quote as what is seen on their dyno when using their latest map and throttle body spacers etc. Therefore, I'd imagine I probably only have around 245bhp.........
                                ......at the moment
                                Cheers,
                                Paul.
