    Originally posted by freddy686868
    Have you got a dta s40 pro? Do you run the flat shift straight off it or do you need another ecu to run the flatshift along side the dta
    I do have the S40 pro. The flat shift is controlled from that ECU so you don't need another control unit. I gave not set it up yet but will do soon
    • TimGR
      • 1041
      #797
      Originally posted by andypipe
      Fitted. Just got to make the mount
      What battery are you using and where did you get it from? How heavy is it?
        It's an odyssey extreme 15 from Burtons. Demon Tweens sell them ax well do dhould be in there catalogue as I don't know the weight
        • reneAE86
          • Mar 2011
          • 80
          #799
          so the into have 200Hk and 250Nm ? I guess and the xflow (1750 ccm ??) 180 hk and around 200 - 220 Nm and again the pinto is 20 kg heaver
          • reneAE86
            • Mar 2011
            • 80
            #800
            BTW you air horns are to cloase to the inner wing you loos power with that installation
              Don't think so. As you can see, they are adjustable and that's where it was best
              • freddy686868
                • Jul 2010
                • 4689
                #802
                Thats good to know for future then as i have a dta and want to run a sequential in the future. Also i see you have adjustable trumpets. How did you do that as i want to start playing with my induction lengths without buying trumpets untill i know what lengths to buy.
                  the trumpets are made by emerald, however an important part of how they work is that fact the flare follows the age old weber 40 dcoe design, you cannot use the adjustable trumpet to decide on a length them use that same length on a more heavily tapered or full radius design.
                  at the moment the trumpets are only avaiable for 42 and 45mm jenveys, however they will fit 48's and 50's, obviously a 45mm trumpet isnt going to have as big a hole as a 48mm body, but as a 45mm tb will easily flow enough air for 260bhp i dont think fitting 45 trumpets to 48 bodies they will hold your engine back one bit.
                  4 x 45 adjustable trumpets are £135 plus vat and postage, i can discount that price down a bit if your interested in some
                  • Nelly
                    • Oct 2007
                    • 726
                    #804
                    Looked like you were going well at Brands at the weekend Andy. It was good to meet you and David and the rest of your crew.
                      Great to see you, hope you're gonna join us in the near future..
