i've been compairing blocks
to use the 205 pump bracket on an early 2.0 block as you say dave you will need to drill and tap the holes in the block out to m10 from m8 and that long spacer needs lenthening by about 10mm,
not so much work then,
if anyones interested whilst i was looking at blocks i got the bathroom scales out, the early block is 2kg lighter than the 205Last edited by Graham; 08-11-2008, 20:53.sigpic
Thinking back, you may have the same bracket that I was given by pace!
And they changed it for the one I have now.Comment
That's just way too nice!
82 Fiesta 2.0 rwd Zetec-t 85 Sierra turbo sold 88 Sierra Cosworth 2wd stolen 86 Sierra turbo soldComment
Not sure how I managed to miss this one - what a wicked project
I seem to be at that funny age where I keep having silly thoughts about 3-door Sierras
Was drooling over a couple at Brands on Thursday too....
Keep the updates coming!
Cheers,
PaulComment
Cheers Paul, yes the ones you mention at Brands are absolutely gorgeous, I was sorry I couldn't make it as I haven't seen them in action.
Will take quite a while before the bodywork on mine gets that good but it gives me something to aim for. Besides its a racecar so will get a bit of a hammering anyway
Hopefully all of the removable panels like doors, bonnet, tailgate, bumpers etc will be off to the painters in the week then the car will follow once they are done. It is only having a freshen up but knowing Ray, our painter he'll want it all done before he lets it go, depends on how much time we get.
.jpg)
RETRO MotorsportComment
Nice project!
I'm not sure if you have solved the diff issue, but the later Scorpios (1995-on) were available with 7,5" diffs with 4.09:1 (8v DOHC) and 4.27:1 (16v DOHC). Usually quite a bit cheaper than motorsport ratios ;-)
They also have a rear beam that is strenghtened in several ways.
GustafComment
Cheers Gustaf, I will investigate this further as that sounds like the solutionNice project!
Gustaf
.jpg)
.jpg)
dave can you please measure your rack between knuckles at some stage please fella?
cheersWanted: Second Hand Tremec TKO 500, 600 or T56 Gearbox... Cash Waiting
thanks Guys !
Will do Ant, as soon as i'm round the garage i'll have a look.
Graham, if you can locate a 4.2 or lower let me know and I'll grab it.
.jpg)
im just basing your diff requirement off my experience with the 2002, i had 200bhp and8k to play with in 800kg, with 15 inch slicks a 4.27 final drive and dirct top, which was great at lydden, a slightly too short for brands somewat too short at silverstone and way too short for snett, but a 4:1 lost some of the magic at the shorter circuits without being a great improvement at snet
so with an overdrive top gear and bigger wheels in a heavier car i would of expected you to need a ratio of 4.4:1
http://www.turbosport.co.uk/showthread.php?t=137067Last edited by Graham; 24-11-2008, 18:49.sigpic
