  • tom burgess
    • 3590
    #331
    As you want more weight over the rear wheels couldnt you have just stripped the front half of the car off and leave all 3 layers of paint on the back?
    sigpictommy 2000
      went shopping today, went to see hp tyres today and came back with lots of new tyres, £2k worth from dunlop
      thankfully i did get a very very healthy discount, but it was still a lot of dosh
      i've never had a proper set of wets before so having bought a set it probably guarentees we wont get a wet race next season, not that i want one, i didnt mind sliding around in the wet in my old car be be honest with 2.5 times the grunt this car scares the crap out of me in the wet
        i've given the exhaust manifolding a lot of thought, the manifold on my 8v car was trouble free, my mk1 16v manifold had 2 issues, the turbo keep working loose, and it cracked, using a sierra manifold last year robbed me of a big chunk of power and the turbo kept working loose anyway.
        thinking about it the turbo never worked loose on the 8v, i can only assume it didnt on that because it was held on with nuts and bolts, rather than just bolts or nuts and studs, so i've decided to go back to my origonal 16v manifold, cut the top section off it and remake it making sure i can use nuts and bolts which are accessable to hold the turbo on,
        the new flange from the manifold is cut from a 16mm thick block of steel, i roughed out the hole in the middle using a pillar drill to drill lots of overlapping holes,
        then used the milling machine to straighten things up
        i picked up this cast turbo adaptor thingy off ebay, its T4/T3, the T4 flange being much bigger i felt would make it easier to fabricate to and having two nice thick flanges on it would be nice and strong and allow plenty of room to bolt things up.
        this flange will sit nicely between the turbo and manifold and hopefully allow the manifold to run cooler and be less prone to cracking, here are some pics of it sitting in place whilst i mocked up
        once i worked out where everything was going to sit, i tacked a couple of strips of steel between the manifold and the steel flange so i could take the whole lot back off the car and start cut and bend some thick 6mm steel plate to join the two together, the only problem being that 6mm steel plate is very difficult to bend, it takes two blow lamps to get it hot and a scaffold pole over an adjustable spanner to bend it all
        • tom burgess
          • 3590
          #334
          Very innovative GrahamI really hope this proves to be a lot more reliable/trouble free way of doing it
          sigpictommy 2000
            Looking like you're getting there graham
            Loving those new wheels you bought, they look hard as nails.
            Wanna borrow one off you one day as I'd like to see if I have the space to run 18's on mine just to keep my options open
            Do you run water cooling to your turbo or is it not worth it? Do you just blank off the inlet and outlet?
              no water cooling to the turbo, you dont blank the holes off just leave them empty.
              from what i've seen and heard very few circuit racers run watercooled turbos because it doesnt do much of a job of cooling the turbo but it does do a really good job of overheating the coolant
              • Dave
                • 19588
                #337
                You can make a very effective furnace out of a BBQ with an air feed under it. (I used a hoover fan )
                You can melt the 6mm plate that way if you wanted to, never mind bend it.
                  You two and Gary should be on scrapheap challenge!
                  There would be an awesome machine built and/or a mahoosive explosion, great tv either way
                    the manifold is completed now, before welding it i bolted it to a spare head,
                    i've tapped the holes in the flange, so the cast t3/t4 adapter will bolt on, and theres just enough room to get nuts on the back of the bolts so i can lock them in
                    im not out of the water yet, as i have a problem when it comes to attaching the manifold to the head, this manifold uses M6 studs, the head was drilled to M8 when the yb manfold was fitted, first thoughts are to drill the manifold to take m8 studs, but the primary pipes are so big the wouldnt be room to fit the nuts
                    IF i can find some m7x1.25 studs, nuts and some m7 helicoils, i can fit the helicoils straight in the current m8 holes in the head screw in the m7 studs and i think theres just enough room in the manifold to drill the holes out and be able to do the m7 nuts up,
                    although what im actually hoping is K nuts are compact enough i can use those with the m8 studs, which would entail just drilling out the manifold which is easier said than done because the primary flanges are a rock hard grade of stainless, i might have to do it the slow way with reamers
                    what ever i do its got to be reliable, i suppose worse case sinario would be to have to change the head on the engine, but that would entail an enormous amount of work porting the spare head, machining valves, shimming, not to mention having to buy another expensive head gasket
                      i'd love to, although i suspect it would piss us off, as i think the team are pretty much told what they are going to do, otherwise when there are a couple of different ways to solve a problem i.e low weight/ small engine or heavy/big engine why do the two teams never take the same route
                        Why don't you turn down some m8 studs to 6mm leaving enough 8mm thread to go into the head and cut some m6 threads on the other ends??
                          i thought of that, infact that is what i did so i could trial fit the manifold to the engine which is still in the car but it leaves the studs very weak, and theres a loat of weight hanging off them.
                          if i could find some OE studs which have been made (rolled) that way it would be a good solution,
                            A lot of production turbo'ed cars use stays/dampers,could you not make some up ?
                              yes i have a damper/ support in mind, although its going to be difficult to get it right, a yb damper is relativily simple because when the yb manifold expands it moves the turbo sideways towards the inner wing, hense yb dampers consiting basically of a rosed joined link that the turbo hangs on,
                              my manifold will try to push the turbo up, so getting it to support the manifold and turbo without trying to break it off is going to be diffcult, i did have a couple of supports for the 8v turbo engine but they just broke every time i did a race, so i left them off in the end, weak studs werent an issue with that engine they were m10!
                                What size are standard cossie studs? As im pretty sure they are special ones for the cossie which are stronger or something....you kinda expect that at £12 each or the extortionate price they charge
                                Faling that im guessing you cant bolt it on with some allen headed bolts?
                                Nice work on the manifold though
